Hallo alle, wo man MTP-Treiber herunterladen kann, um das Telefon an den Computer mit USB-Kabel anschließen?
Hello everyone, where you can download MTP driver to connect the phone to the computer with USB cable?
GT
Hi @CatDEXZ1;
First of all please post your questions in English as this is an English based forum and for everybody can help you.
Regarding your question go to settings >Device Connection >USB Connectivity >install software.
Thanks for the tip All this I tried nothing helps:smileyrolleyes:
win 10 home 64bit
Hello everyone where you can download MTP drivers to connect the phone to the Computer with USB cable?
When you connect your device with the supplied USB cable to the PC what happens?
If you are just looking for the drivers you can found them here: https://developer.sony.com/develop/drivers/;
If you are having problems with the connection read also here:https://support.sonymobile.com/global-en/xperiaxz1/faq/the-phone-doesnt-appear-on-the-computer-when-....
Nothing happens, the computer beeps and that's it
If it makes a sound than the connection is detected, have you tried all the tips in message 8 link?
Does the phone gets charged when connected to the PC?
Have you tried connect it to another PC?
