I have huge and several problems with my phone (XZ3) after the latest Android 10 update.
-Lag, delay and slow working apps. Also between switching and opening apps.
-closing apps by itself
- clock and alarm is not working right. After sliding "turn off" it still starts ringing again.
Is there any solution to fix these problems?
The solution is to either try to Rollback to Android 9 or get a new phone
Same with my Phone. Any official Statement?
Проблемы с телефоном после обновления на 10.
Problems with the phone after updating to 10.
gt
I used xperia companion software repair. Phone works again, secons Day, no problem
Do you have any problems with hdr content? When i watch hdr content on netflix or YouTube, even hdr videos in my own Gallery, colors are faded as if there is a gray film put on the screen. It definitely not like that before. Anyone has that?
Yes same with u
Yes hdr on YouTube does not work corecctly. See autorotate, you can See between changes
Yes... When you rotate, you can see true colors for less than a second. Same as you take screenshot from it.
Absolutely Great, after reset the restore from Googel Drive doesn't work!!!
I tink that was my last Sony mobile phone
