Hi
Just received a brand new (sealed) boxed Sony Xperia XZ3 (Model H8416). It is currently on Android 9 Build number 52.0.A.1.215. However despite going into settings , system, Software update and System then refresh, it says "Your device already has the latest available system updates". I've had the phone for about a month with no sign of any update to Android 10. I have also tried the Xperia Companion but it says that everything is ok.
So basically how do I go about upgrading my XZ3 to Android 10.
@BBC-Man I would recommend using Xperia Companion to update it: https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/xperia-xz3/articles/0...
Hi
Thanks for help but already tried using Xperia Companion and didn't work as I put in my original post. Any other ideas?
@BBC-Man Try to follow the steps here: https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/xperia-xz3/articles/0...
Hi
Thanks for that but again already tried every combination of using the Xperia Companion, even doing a manufactures reset on the phone, but still says that there is no update. I have also tried using different cables different computers and taking the SD Card out of the phone as well.
@BBC-Man In this case, maybe you need to contact the service center that repairs Xperia devices on 01233619320 to inspect your phone.
