From The last week I have to chatge 3 times a day.
Any idea?
Thanks
i have the same problem. It is looks like wifi and btooth drain battery. Something is wrong, maybe someone knows how to solve this issue?
Same to me: After 3-4 hours without usage the battery is empty!
Have you checked the batery usage screen? It has a list of apps and how much battery each has used.
Go to
Settings | Battery
and touch the battery symbol. This will take you to the battery usage screen. The app with the highest usage will be the first on the list.
I have the same issue since last week. Before that i was able to stay 2 days without charging with a normal use. Any last Sony update may be causing this?? I'm now charging even twice a day!!
