Solved! Go to Solution.
Well there you have it, even if you don't open the app (facebook) it will continue running in the background, facebook, whatsapp and chrome are the top battery hog apps
As long as you have those apps running, constantly the battery will continue to drain, you could disable/uninstall facebook and only use it on chrome or other browser, that way it will only sync whenever you open it.
