Camera does not focus correctly
SOLVED
Cydrich
Visitor
The title basically tells it all. I have been experiencing this for quite some time. Sometimes the error can be "shut off" by restarting the camera app. At least for a while. But I also had the camera become unfocused on the middle of a movie.
Once the error occurred it had never repaired itself "by itself". I always had to restart the application.
I just installed the new system update to 5.1.1, but it didn't get better.
Anyone had this problem and had a solution?
Thank you!
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.US.title
Qatrium
Try clearing camera app cache:
- Go to Settings -> Apps -> All -> Camera -> Clear data and restart your phone.
5 REPLIES 5
Phy
Legend
Legend
Take a look at the camera lens, are there an scratches on it or is there any dirt or particles on the lens?
Qatrium
Uliwooly
@Cydrich
You could repair the phone with PCC but it might be a hardware issue
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Cydrich
Visitor
The trick with the clear camera data and restart seems to have done it.
Many thanks!
Cydrich
Visitor
Well, it seems, that either I have to do this trick quite often, or maybe I was too optimistic about the solution.
One more detail : when I try, to take a picture, that requires macro, the camera continues to focus just fine (and the macro sign appears). If I go for something not macro, the sign disappears and the focus unfortunately disappears as well.
