Can't detect bluetooth speaker
Xp5
I cpuld not reach a bluetoothbox with my new xperia 5. With my old samsung 3 or 4 No problrm.. Also the people in the store could not help meee
Topic edited by Rickard
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Lord_viridis
Try this from the fruity forum...
I found the solution.
Start bluetooth on the xperia
Start the JBL speaker, the button lights blue and you hear a short warning-sound.
Now push the startbutton on the JBL again and hold it.
The light turns red.
Look at the xperia and after a short period the name JBL pops up.
Stop pushing the "red" button at the JBL
Select the JBL name at the xperia to connect.
When it is connected or paired, your done.
The next time you want to connect the JBL you do not have to repeat the above, because your Xperia knows you have a JBL.
8 ODPOW. 8
NeoBeum
Znawca
To stream music?
Uliwooly
@Xp5
Have you paired the Z5 with the bluetoothbox?
Xp5
Couldnot see my box... Bit see tvs not from me
Uliwooly
@Xp5
could you elaborate on which bluetooth device you are trying to sync?
Lord_viridis
Jbl flip speakers I'm thinking..
I'm sure the later models are NFC ready which will negate the need for manual bt pairing.
Xp5
But sams g 3 and 4 bo problem... I could not see my jbl flip or my diamond..
Lord_viridis
Have you put your flip into pairing mode?
Lord_viridis
