Headset not supported
kellyh1991
I keep getting a message flash up in my phone saying the headset is not supported change headset or go to sony support page but couldnt see anything. Anyone have any idea what it could be
86 ODPOW. 86
zzz119
If you can't find alcohol to spray then use perfume or clones. They have iso propyl alcohol base so performs the same.
Atou
Hi. I've been getting random "headset not supported. Visit sony....." message even if there isn't any plugged headsets on my phone.
I've even tried uninstalling smart connect but its still not working.
Teknikaali
What finally helped me was to wipe the headphone plug (add some alcohol if you want..), plug it in, give it a little twist back and forth (to get dust and dirt out of the input socket). Finally blowing the headphone jack hole like some good ol' NES-cartridge made the messages go away. Also try uninstalling the updates if this doesn't help.
Dreamfires
Im having to same problem on my Z1 and so my husband. Some days it fine not message pops up. Other days it's poping up all the time. Sony please fix this.
Abchief
Disabling Unsupported Headset Notification app in your settings works. Not sure if this app will restart itself.
jky28
SAME HERE. THIS "HEADSET NOT SUPPORTED" BUG IS REALLY ANNOYING. IT KEEPS ON POPPING UP!!! SONY PLEASE DO SOMETHING ABOUT THIS. IT'S UNTOLERABLE. ALSO PLEASE IMPROVE THE CAMERA OF Z1 COMPACT. It aggresively pumps up the ISO level in most cases using AUTO MODE. it is supposed to be SUPERIOR.
Kholoud
Headsets not supported .. I try every thing Slightly_frowning_Face
After update software Slightly_frowning_Face
Uliwooly
@Kholoud
Test a different pair of headphones and report back.
CameronT
VIP
Hi @Kholoud,
Welcome to the community.
When you say you have tried everything, can you please advise us of the steps you have taken so far?
Can you also please advise us what headsets are not working with your phone?
Kholoud
I tried more than one .. It dosen't work
