Hi everyone,
The drag down quick settings menu has disappeared from my Z3. Dragging down from the top with 2 fingers does not bring the menu down. Neither can I use the notifications at the top right to access the menu. However, I get to the sounds setting panel by using the volume button.
Tried this:
Settings > personalization > Quick settings
but I do not see Quick Settings option.
any suggestions pls? thank you
That's quite odd, you might want to repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
Does it work if you boot on safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
@uliwooly
no it doesn't
Bridge (for Mac)
did the repair/factory reset and i can pull the notification bar when i open an app in the landscape mode. bummed. but could be worse.
i'll give it till the end of the week before sending it to the service center. before i did the repair, i turned the alerts on for whatsapp. when the texts came in locked screen, i couldnt unlock the phone coz it kept flickering. i had to press the camera button to activate camera mode, exit then go to the lock screen.
not sure if it is a case of this
thank you for all your help
@Nailz
I cldnt work it so I took it to the service center yesterday. the staff ran the diagnostic test and said the phone needed a LCD replacement.
Try this, Settings >> About Phone >> Diagnostics
Good luck
