Solved! Go to Solution.
I've got the Xperia Z2 and suffer from the same bug..
from Android 4.4.2 to Marshmallow 6.0 (Beta until now).. Always blurry pictures,
I'm embarrased of taking pictures at partys and clubs because then there is always this reaction:
"OMG your camera seems to be very...well...weak." But my phone isn't weak, I love it but the camera.... NOPE!
The only solution that works for me: Use KiwiCamera, it's the only app that seems not to use Sony's image "optimization",
but it takes 3 seconds or so to process a picture.. But it is the only way to shoot reasonable pictures at low light conditions.
I hope ONE DAY this bug will be fixed but until then... happy frustration!
I camera wont to turn off soft skin effect,pls help.
this problem is stressing mee!
It's 2018 and still no response from Sony even after the issue being"escalated". Ridiculous.
what will i do to remove the soft skin effect? I'm using Z3
It's 2019, and Sony doesn't fix, doesn't respond to this topic. You are ridiculous Sony. I am very disappointed because I bought this Xperia XA2. I will not recommend anyone to your products. Sony - a team of unprofessional.
Do not use auto ISO, set it manually.
