Hi there
Bought an Xperia Z about a month ago. Had slight lag issues but nothing too serious.
My phone ran down and the battery died two days ago. I put it on the charge (its been on the charge pretty much ever since) with the red LED lit up. LED turns off completely when unplugged.
Phone will not turn on at all; have tried all of the manual resets (holding power button and volume button etc); have read these forums and searched the web for a solution to no avail. PC doesn't recognise the phone so can't reset it via PC Companion. Basically, I have an $800 unresponsive brick.
Very very disappointed to say the least. Phone was very well looked after, and to have it die simply because the battery ran down is extremely worrying. I've seen that this issue is very common yet there doesn't seem to be any definitive fix for it whatsoever.
Any help that anyone can give me would be really appreciated
Hi guys. Same problem with my xperia z. I read the solution about connecting it to a wallet charger etccc. Is it normal that no led light? Do I continue to wait the hour? Or it is useless? please help me.........
How did you solve this problem?
Easily fixable on your own, check out my video guide Hope it helps
My phone is dead. Wont charge. Bought a new one - not Sony but sending old one to be recycled. I need to get some family pictures off before though.
Can anyone help - how can I get it going just to do this?
my experia m2 wont turn on and pc wont recorgnise, sees it as QHSUSB
I managed to get my Xperia on!!!!
Connect it to the laptop turned on and it springs into life with the green charging battery symbol. Then just let it charge up.
I've tried for weeks to get mine on and eventually bought a new non-Sony phone but this is worth trying. Worked for me
Ok i need help,my Xperia Z cant turn on i tried power button volume up and down and it isnt working,there is just a blue led light flashing if anybody knows what is going on please say
