unfortunately memory has stopped
Stigdaniel
Visitor
When I try to transfer data from the internal memory to my SD-card i get the message "unfortunately memory has stopped". The SD-card has worked before as well as the transfer feature. I think this started to happen after a warranty repair of my 3.5 mm stereo connector. Any clues about what to do?
14 REPLIES 14
CHAMP78
Visitor
@ThaFixer
jjjjjjjjj888778
Visitor
hi, how do you disable the app? my disable is grey
Unfortunatelyme
Visitor
unfortunately memory server has stopped?
Luckyoreo2019
Visitor
Memory has stopped even though i put in a new sd card and still indicated that the memory has stopped. Iv restarted with  sd card in place and still it's not working.
Luckyoreo2019
Visitor
Where did you find the memory app as I couldn't find it.?
