went oFf i have chargeit for hours now green when chargers in tried both things to restart power up
cookieajc
Visitor
Hi i have a z2 but It
1 REPLY 1
Martin1
Enthusiast
Hi @cookieajc, let me see if I can help out here.
So if I understand you correctly, the LED light of the phone lights up in green when you connect the phone to a charger, but the phone will not boot up as usual? Please correct me if I have misinterpreted your question.
One thing that might do the trick in order to start the phone up is to force a restart of the phone by pressing and holding the power-key and the volume up-key simultaneously for ten to fifteen seconds or until the phone vibrates.
If a forced restart procedure as described above doesn't succeed in turning on your device, you should try another kind of forced restart - the two-minute restart procedure using the steps below.
  1. Open the SIM and/or memory card slot cover.
  2. Using the tip of a pen or similar object, press and hold down the small OFF button (generally indicated by the text "OFF") for 120 seconds (ignoring any vibrations), and then release the OFF button.
  3. Charge the device until a charging icon appears on the screen.
  4. Turn on your device.
Try these measures and let me know how it goes!
