Hello,
soon in Germany, the Xperia is to buy! Then I buy immediately.
But two questions beforehand:
1. External Memory - Micro SD 32GGB or MICRO SDHC 32GB?
2. In delivery, there is a protective case?
Sorry for my english, this is google-english....:smileysilly:
thanks, Bernd
Hi, hotzi57
I understood what you wrote above and i hope you undestand my english. I'll try to be as simple as i can
1) Cards with higher storage come with SDHC tag .
32 GB SDHC will work perfectly with Xperia Z
2) In box contents varies from region to region. Once Xperia Z is release in your country , you can give local Sony support a call to know about the same
Hi, hotzi57
THX! Great!
