Xperia Z1 does not charge!!!
SOLVED
ingol
Visitor
Hello,
I've already searched for this problem here, but mine is too strange.
I was using my phone normaly and the same day hour before it happens charging in a car charger.
When my battery reached 2% i turned it off and conected to the charger and went sleep, when i get up i tried to turn it on and nothing... no red light flashing, cant recharge and the power + vol up isn't vibrating and no response.. while i write this, its attached by usb in my computer and the companion can't find it either.
anyone can help? i hope that my phone is ok..
thanks
12 REPLIES 12
druword
Visitor
when ever i plug my phone to the charger it shows o% the the led light gos off i press the lock botten to check if it's charging then i see 50%. tried to turn it on but it won't.. i have changed 3 batteries in just two days... please i need help
Tags (1)
Uliwooly
@druword
Then the problem might not be the battery but maybe a ribbon or something else.
jamal8
Visitor
hey im so gald ive got this forum to turn to. my sony xperia z1 seems to have been in some kind of non responsive mode. if i connect a charger the red light blinks 3 times and stops. doesnt appear to be charging. my phone is the module with the front camera on the right of the sony logo, and the rear camera is on the left with the flash exactly beneeth it
