Create AVCHD format disc
profile.country.en_GB.title
DB1960
Visitor
Can't create an AVCHD format disc either from PMB or direct from Handycam. Get error message PMBHDAuthor.exe has encountered a problem and needs to close. Any ideas?
1 REPLY 1
profile.country.hr_HR.title
DamacizSi
Visitor
You did not say model but I guess it is HD camera Sony. So, if You use PMB You should best use AVCHD supported disc and mybe Your grafic card on PC does not support avchd format//
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/index.html
