PMB always crashes!
profile.country.en_GB.title
fabriciusf
Visitor
PMB always crashes!
I have now tried to get PMB to work for 3 years. On multiple operating system versions and multiple PCs. I have tgried on PCs where I have not installed Photoshop - which I suspect uses CODEC PMB can't handle.
Installed the latest version this morning - and now it crashes even faster!
I have never tried a program like this.
2 REPLIES 2
profile.country.hr_HR.title
DamacizSi
Visitor
Best way is to install original version PMB but, on PC deinstall codec packs all...like K-lite ect. it can realy disturb. Reset PC and install latest firmware update for Your grafic cart. Turn of sicurity program like fire wall when installing PMB if needed.
:slight_smile:
profile.country.sv_SE.title
petstrm34
Visitor
Do you use PMB for a AVCHD Sony videocam?
I have used it for three years without any problem what so ever,
except it does not run under Win 7 32-bit.
Win XP and Win 7 64-bit is perfect.
Peter
