Sony Handycam blurry, when zoomed in not?? HDR-CX100
maartenvanhenkel
New
Hey guys,
After looking around the net i didn't find an exact answer so i try it here.
My sony Handycam used to work good, but now when i want to record the whole screen is blurry and when i zoom it at some point everything becomes clear, and when i zoom in more it becomes blurry again. So there is like one zoom point where everty is okay, but the rest of the time everything is blurry?
I think the auto focus is ON, All options that i found are on AUTO. So the 2nd option is that the lens is broken? But if so why would it work at some zoom point?
1 REPLY 1
cass_n
Hi @maartenvanhenkel,
It does sound like the lens or focus motor driver might be broken.
You can find out how to get it repaired here: http://services.sony.co.uk/supportmvc/en/repair
Thanks,
Cass
