Just acquired this stereo, with full instructions, and I have set up about 6 pre-set radio stations - the mystery is quite how I can then select any of them !
The remote control does not have the usual numbered buttons and User Instructions are quite vague about how to select, say, radio station preference '1' - any advice/guidance please?
Thanks for advice - I have tried the repeated clicking on 'Tuner Mode' button but 'Preset' never comes up!
I will certainly try it again but - help me out - which are the +/- keys to press, in next step? I only see those makings on the Volume controls !
Tuning Mode > One of Number 14...
+ and - in Red Circle...
I think and I guess... 🤗
I have another Sony stereo (the handsets have actually proven to be interchageable!) and I can change pre-set stations on it, using the +/- buttons, located just below the 'tape' & 'cd' buttons, so I guess that's what the instructions mean.
BUT the same action doesn't work on my new device, which seems a bit crazy! When I press those =/- buttons, on either handset, to the new device, it just cycles through the wavelength, stopping wherever it detects a signal, not going to the next pre-set !
Maybe it's just a piece of defective kit but - still - any ideas will be very welcome, asd it's pretty useless as it stands!
My yellow shows the correcct +/- to change the stations, for information.
Good point about 'correct' entry into station pre-set memory!
I will do it again, in case I've got in wrong, will let you know !
Sadly, re-entering preferred stations in FM or DAB has yielded no improvement - doh!
