BDP-S370 and AVCHD play back.
wasted.d
Explorer
I purchased a BDP-S370 just before christmas and was loving it,  i found no issues with it at all. Then a new firmware came out and i updated it,  this seemed to go well an everything was as it was before untill i went to play a AVCHD Disk.  I have been using AVCHD disks for a few yrs now usually i played them on my ps3 but after getting this player i swapped the ps3 for it as my main player.  Now since the firmware update my AVCHD disk keep stopping,  well actually the video stops but the audio continues then after a few seconds the video jumps forward to catch up, this continues untill the movie ends.   The disks still work fine on my ps3 and pc.
I have reburned them using different media,  different software.  I even had my dad take one of the disks home an try it on his BDP-S370 an it does the same thing on his.   These disks worked fine before the firmware update and i wondered if anyone else has had similar issues.
0 REPLIES 0
