DAV-TZ715
SOLVED
Korabid
New
DAV-TZ715
Hi I have one DAV-TZ715 Home Theatre System but is peasing me off because in some days of the month it shut downs automatically. Also after I turn it on after few minutes it shuts down. Some days of the month it doesn't happend. I tried to find where to stop or reset to factory settings but I didn't find any solution yet! I find one but it didn't work on my model.
Please help me.
Best regards
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
Sounds like your DAV system has PMS.  None-the-less, you can factory reset it by:
Cheers
2 REPLIES 2
Anonymous
Not applicable
Hi there
Cheers
ojamesodanga
New
Cold reset worked. Bravo!
