Hi, Seems the dvp - S330 was the USA model, did the U.K have a different model number ? but with the same guts inside.
Can anyone help.
Thanks Clifford
Hi there
I have forwarded this thread onto Sony Support to answer. I have had a dig around and I cannot get anywhere to be honest. I cant even find an exact release date - although 1999 seems to come up.
Anyway, Sony should be in contact with you.
Cheers
Thanks for that, yea i have a search online but like yourself i got no where.
Hi there
I received the following response back from Sony today:
After some research, unfortunately it seems that there was not an exact equivalent that I can find released for the UK Market.
The best I can do would be to suggest some similar models which may still be commercially available from some retailers in the UK:
DVP- SR760H
DVP- SR170
DVP- SR750H
Hopefully this helps.
Cheers
