HT-XT3 using USB stick to play MP3s (image)
hardtoplease
Explorer
I sent this to Sony support but received no reply. Any ideas ?
"HI ...thanks for previous help, hope you can advise me here.
I play music recorded a USB stick through the XT3.
The background image is as below. Can I change this image (spheres) either on the soundbase or my Sony 42" KD smart TV ? (see attached image) Many thanks"
2 REPLIES 2
Anonymous
Not applicable
Hi there
What you can do is use your own photos and play music over it in the background.
You will need to have a look at the following open on page 28 of the manual HERE - 'Add slideshow BGM'  (Background Music).
Another explaination of this feature can be found : HERE.
Other than that, that it.
Cheers
hardtoplease
Explorer
Thank you Quinnicus.  this sounds as though it will be the ideal solution.   J.
