HT-XTR
DBNorth
New
HT-XTR
Thinking of getting the HT-XT3 sound base to go with my KDL-47W805A Bravia TV. On the whole I've read good things about the sound base but have some concerns about lip sync issues. Is my TV modern enough not to have this problem?
Tags (3)
1 REPLY 1
Anonymous
Not applicable
Hi there
If you purchase this soundbase, simply connect it to the TVs HDMI-ARC port using a HDMI cable - ensure that you enable Bravia Sync and Control for HDMI HDMI (should default to ON anyway).  In regards to your question about Lipsync, there are adjustments if needed.  See page 29 of the manual HERE.
Cheers
