HXD860 HDD No TV Signal
Hi, I have a trusty HXD 860 HDD which has recently developed a problem.
We recently got BT TV whch has meant disconnecting and then reconnecting aerials from our TV players.  When I disconnected the aerial from the HDD I noticed that the cable end was badly corroded.  When I tried reconnecting the aerial I now get no TV signal.  No programmes are found when I try to retune the player.  So, I am unable to record any programmes now.
The aerial cable is connected to an aerial amplifier and all is new.  I'm wondering if there is something wrong with the aerial-in connector on the HDD.
Any help would be appreciated.
2 REPLIES 2
Anonymous
Not applicable
Hi there
Its not clear - but did you replace the aerial cable that was looking corroded?  If not, thats the first thing I would try.
Cheers
Yes, it was just the last half inch or so that looked corroded so I snipped this off and made a new connection.
