Low Temperature
Low Temperature
i have a Sony Blu-Ray player (BDV-E280) which will not operate if the room temperature is below 14-15 degrees C, does anyone else have problems like this?
1 REPLY 1
Anonymous
Not applicable
Hi there
Although I cannot find the exact figures, many electronic devices only work properly between a min and max operating temperatures.
See:
https://en.wikipedia.org/wiki/Operating_temperature
However I would have thought 14 degrees is a bit high for a minimum temperature - maybe the system has a bit of condensation build up, which may cause a short in power.
Cheers
