Sony HT RT3 connection via BT to Samsung TV
hi All
is it possible to connect Sony HT RT3 home cinema to Samsung Curved EUJ6300 via bluetooth? Or the BT it is only for portable devices for short distance connections? I know there is optical Toslink connection, however I would prefer to minimize wires at home.
thank you
1 REPLY 1
Anonymous
Not applicable
Hi there
The HT-RT3 is designed to connect to a TV via optical connections.  Besides, I do not know if Sammy TVs can output audio via BT to a Soundbar.  If you have the HT-RT3 already, just test it?
Cheers
