Sony UHP-H1 Click when changing tracks on Multichannel SACD
Sixtyten
New
When I'm playing the multichannel layer of SACD discs if I use the next track button on the remote control to advance through the disc I hear a click thorugh my speakers immediately before the track starts. This is not specific to a particular SACD disc, it occurs on every SACD disc I've fed into the player and played the multichannel layer. I press next track, then there's a single click, then the track plays. This happened on the two UHP1s I've had. It does not happen when I play the same discs back on either my Denon DBP2012 through the same Pioneer amp, or on my Pioneer DV565 through my old Yamaha amp.
Something isn't right.
1 REPLY 1
Anonymous
Not applicable
Hi there
I have escalated your issue to Sony Support - I am unsure on how to help you on this one im afraid.  Sony Support should be contacting you within the next couple of days
Cheers
