CD jammed in drive
profile.country.en_GB.title
Alfreday
New
CD jammed in drive
I have a VGC - LN computor. I have a CD jammed in the  drive which will not eject. I have previously be able to remove a jammed CD with a pair of tweezers. Will I have to remove the rear cover to get at the drive?
Alfreday
   There isn't a small hole beside the drive. I am pretty certain I will have to remove the rear cover to access the drive. But am unsure which of the screws in the cover I will have to remove.
  Alfreday
Message was edited by: Alfreday
Edited by Alfeday
1 REPLY 1
Blencogo
Hi Alfreday and welcome.
Have you tried straightning out a paperclip and pushing it into the small hole beside the drive slot?
:thinking:
