VAIO All in one desktop - VGC-LVIS help
profile.country.en_GB.title
simonpeter
Visitor
I have just upgrade my VGC-LVIS VAIO PC from Vista Home Premium to Windows 8 Pro and have lost the TV function. It appears that I need new drivers which support Windows. Any advice or help on this and where I can obtain them would be appreciated. SimonPeter
1 REPLY 1
Blencogo
Hi simonpeter and welcome.
Unfortunately, Sony does not support Windows 8 on your model and so there are no Drivers or Utilities available for Windows 8.
I presume you have tried re-installing the original AverMedia A313 TV Card Driver which was designed for Vista?  You will find it here under the Preinstalled Drivers & Utilities Tab:
http://www.sony.co.uk/support/en/product/VGC-LV1S/updates
If this doesn't work, you will have to Google for an AverMedia A313 Driver compatible with Windows 8.
Without Sony driver support, I expect you will find other things don't work either and you may have to consider returning to Vista or Windows 7.
:thinking:
