I have a Vaio Tap 20 which, after 2 weeks, has suddenly developed a thin bright green line vertically down the screen. I have rebooted etc but the line won't go away. Does anyone have any suggestions for what might cure the problem?
Thanks,
Peter
Solved! Go to Solution.
Hi Peter,
welcome to the Sony User Community..:smileyhappy:
As your Tap 20 is only two weeks old I would be inclined to suggest you contact Sony support as your Vaio may require repair/replacement..
To locate contact details for support please click the following link - Sony Support
Hi Peter,
One month old and exactly the same problem about to return computer to Sony for repair I hope this isn't going to be a recurring problem.
