Self Heal Hangs
profile.country.en_GB.title
clwhite33
Visitor
Self Heal Hangs
Hi,
I've been running Vaio Care, One Click Care. The programme runs for while, then hangs when it gets to Self Heal. No eror messages of any kind. Any ideas? (W7 64 bit OS)
Regards,
Clive.
5 REPLIES 5
peshyxp
Visitor
If its hanging then there is probably a software issue somewhere
I would suggest booting into Safe Mode (hit F10 when booting up) and then uninstalling the Vaio Care programme through Control Panel / Programmes
This should do the trick and you can then reinstall again
If not post here for some more advice
clwhite33
Visitor
OK, Thanks. Where can I reinstall it from?
nikkilim
Visitor
You can uninstall it from Add/Remove programs.
To install it, you may need to download the installer, if you don't have it in the support site.  https://www.sony.co.uk/discussions/message/761158#761158
Blencogo
If you give your Vaio Model, I'm sure someone will give you a link to the Downloads Page.
:wink:
clwhite33
Visitor
Solved! Zone Alarm was blocking the progress of the programme.
Fixed now and everything seems fine.
Thanks for your interest.
Regards,
Clive.
