Sony Vaio Laptop Repair in the UK?
SOLVED
Martinrub
Explorer
Can anyone recommend a competent, trustworthy place in the UK to send my 10-year-old Sony Vaio laptop to for repair?
There is a fault on the motherboard, and, so far, I have approached 4 places without success.
Thanks.
2 ACCEPTED SOLUTIONS
Accepted Solutions
Joe_Dohn
Specialist
Martinrub
Explorer
After going around the houses, I finally found out that there is only one approved Sony repair centre (for Vaios, anyway) in the UK.   It is:
CTS
16A High View Drive
Chatham
Kent
ME5 9UN
PHONE 01634 681111
many thanks for your kind help putting onto the right track.
13 REPLIES 13
Joe_Dohn
Specialist
Doesn't get more trustworthy than authorized Sony service centres.
Martinrub
Explorer
That was the first place I looked at, but when you visit the authorised Sony Service Centres, laptops are not on the list of equipment they service, no doubt because Sony abandoned laptop production a long while ago.
Joe_Dohn
Specialist
Did you use the "Personal Computers" filter when searching?
Martinrub
Explorer
Many thanks. That option didn’t appear on the page I first visited. But it is on the page I have now found. There appears to be a place in Pencoed and one in Chatham, so I will contact them. Many thanks.
Joe_Dohn
Specialist
Glad to hear that ^^
Be sure to mark the thread as solved once you get some feedback so others can benefit as well
- JD
Martinrub
Explorer
Will do. I’m just waiting for a callback from the Vaio team and then I’ll be able to add something useful, and positive, I hope.
Many thanks
Martin
Martinrub
Explorer
CTS
16A High View Drive
Chatham
Kent
ME5 9UN
PHONE 01634 681111
Joe_Dohn
Specialist
Hey @Martinrub,
It's a pleasure, and you've just added all of the needed information for anyone else in the future, so thank you too ^^
- JD
BoodjerPisdjer
Explorer
I’m happy your problem is solved but I guess there can be other users who need some tips.
