WF C500 ear pods : can I turn off button controls?
SOLVED
Putneymum
New
Hello.
I bought these ear pods after seeing them being reviewed on Tech Radar as being great to help you get to sleep as they’re comfortable. However, sleeping on my side activates the button controls as i lean the side of my head against the pillow until it makes a beeping noise, meaning I can’t sleep with them in!
is there a way to deactivate the button controls ??
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
jumpsuit
Hi @Putneymum and welcome to the Community :slight_smile:
Unfortunately you can't disable the button controls on the WF-C500.
2 REPLIES 2
jumpsuit
Elodin
Moderator
Hey @Putneymum, as @jumpsuit said you can't disable the button controls on the WF-C500
