Hi, I’ve these earbuds for almost a year now and absolutely love them.
Howevere after the latest update the left earbud started draining like crazy! I haven’t changed any settings. Also the right one drains faster than before but compare dto the left one it’s noticeable slower. Please see the screenshots attached. Look at the clock it’s not even 60 min of usage:
I tries both but the issue still persists 😞
I have the same issue. Battery drains within 45 min
Hi alsalehyaa, it's time to send it for inspection, when did you purchase them? And did you ever try contacting Sony?
Mine is over a year ago. I’m sure the warranty already expired!!
Hi,
I've the same issue, seems to be a common issue with firmware 1.42, other discussion recommends either to downgrade, wait for a new firmware or request a replacement .
Anybody found a solution for it?
