- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Februar
Februar
Creator App unable to access memory A1
Hi,
when i try to access the memory of my Sony A1 via the Creator App i get an error message stating:"unable to access memory. Please check your camera"
i tried repairing phone an camera but it didn’t help. Remote shooting on the other hand works.
Firmware is Version 3.0. worked fine before the update.
Help greatly appreciated
EDIT:
i removed the battery because i had to swap batteries and all of a sudden it works. In Case anyone has the same issue and wants to give it a try
1 ANTWORT 1
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Februar
Februar
@Samuel_K Did you reach out to Creator's support? It could be a technical issue with the new software. Alternatively, you can try inserting the memory card into a card reader through a PC or a laptop.
