Does Xperia 1 support Dolby Vision?
ds2mph
Visitor
NTT Docomo says Xperia 1 supports HDR10, HLG, and Dolby vision, is it true?
https://www.nttdocomo.co.jp/product/smart_phone/so03l/spec.html?icid=CRP_PRD_so03l_to_CRP_PRD_so03l_...
17 REPLIES 17
profile.country.PT.title
NunoSEN2
Hero
Hi @ds2mph ;
According to the Xperia 1 specifications that can not be true because the screen uses a 10bit tonal gradation (8bit with 2bit smoothing) and the Dolby Vision uses 12bit.
Besides, according to the Dolby site the phones with Dolby Vision are: https://www.dolby.com/us/en/technologies/mobile/dolby-vision.html.
ds2mph
Visitor
Does it mean LG G6 has 12-bit panel and uses a 12-bit tonal gradation?
NunoSEN2
Hero
@ds2mph ;
I don't have much knowledge in LG phones but if Dolby says they are complient with Dolby Vision then I suppose so (but only when viewing Dolby Vision content).
In the LG G6 webpage what is said is that the content must also be recorded in Dolby Vision format (or HDR10) to take advantage of it, so probably in normal viewing you don't have the full color depth.
ds2mph
Visitor
I think that phones on the list (LG G6, iphone8,xs,xr) can just play HDR videos with Dolby vision, not fully support 12-bit because they seems to have 8-bit panel.
Now I wonder whether NTT Docomo wrote it by mistake, or not. I'm waiting for a reply from official staffs @Jonas @Martin
Thanks for your reply @NunoSEN2
By the way, how did you tag me? I can't tag someone @NunoSEN2
Lord_viridis
@NunoSEN2 wrote:
Hi @ds2mph ;
Looks like that list needs a bit of updating tbh.
I'm pretty sure more devices than that are capable of DV
NunoSEN2
Hero
@ds2mph , I think you need to be a Pioneer, Moderator or Xperia Support Staff to tag Forum users.
digitalray
Member
dolby vision has several DV profiles for TVs, Mobile Phones, Tablets and cinemas.
12 bit is only supported in single cases for cinema movies, but not really for DV TVs, they only support 10bit display (although the processors can handle 12 bit and transfer it to the 10bit (or rahter "9.5bit" panels with about 500 million different colors.)
what the xperia one does, is taking a software HDR Signal and then it's putting it it to a display with a 50% BT2020 color space in case of the XF90 Dolby Vision enabled TV.
in my definition that phone could support DV from the bits as processing should be quite possible and thats the only thing what dolby is certifying, they dont care about the display as there are no tv or smartphone displays that are higher than 10bit on the market.
maybe dolby just needs more time to certify that phone as DV compatible and to create a phone specifiv DV profile.
NunoSEN2
Hero
@digitalray78 ;
I think any display to be Dolby Vision compliant must support a 12bit color depth, please read here: https://www.dolby.com/us/en/technologies/dolby-vision/dolby-vision-white-paper.pdf,
or here specific for mobiles HDR information: https://www.androidauthority.com/mobile-hdr-necessary-800786/
digitalray
Member
"The single layer HEVC Main-10 profile of Dolby Vision can be decoded by a standard HEVC decoder, then post-processed using a Dolby Vision module to produce the full range 12 bit Dolby Vision signal. "
So.. the DV Signal is 10 bit, it get's 12bit when the final consumer product processor it to it's color space with the "dolby vision module". and then it gets projected onto whatever display, in consumer times today these are 10bit displays for tv and smartphones.
the XF90 TV Display can output 1000 nits total brightness (about 600 in usual scenes where the whole screen is not total white) but only 500 million different colors, thats half of 10 bit capability.
so you are right, for a DV certification, the Xperia One needs to be able to produce a 12bit signal in its processor . The Xperia One supports BT2020 color space, although BT2020 can be 10bit or 12bit.
so i guess we are left with originally 10bit 2020 HDR10 Signals that are not even DV processed to 12bit on the Xperia One and are either way displayed on it's not even 10bit display, which makes sense in the end if the displays can not handle 12bit or even a full 10 bit anyway (xp one display is a 8+2 FRC Display, more info here https://www.newsshooter.com/2019/03/07/sony-xperia-1-worlds-first-219-cinemawide-4k-hdr-oled-display...)
read this: https://referencehometheater.com/2018/commentary/sony-x900f-image-quality-review/
and remember that the XF90 is officially Dolby Vision certified and enabled.
a nice german article for translation purposes: https://www.heimkinoraum.de/tests/dolby-vision-vs-uhd-premium-hdr10-166
