tech help
st3velj
tech help
Hi   Im interested in the xperia 1 iii.   Can anyone tell me whether it has the double tap to wake and double tap to turn the screen off please.
Cheers
3 ODPOW. 3
Piscie
Hey @ st3velj, the double tap feature doesn't turn on/off the screen, yet this feature is supported for the One handed mode and adjusting the side sense as explained here.
Lord_viridis
Once the ambient display shows up, double tap will open the lock screen, I have to wave my hand over it to enable ambient display, then I tap twice
Unfortunately the tap to display off, is not supported.
Piscie
Yes, you're right! My bad. I just double checked and I found out that the double-tap to wake up feature won't work unless the Ambient Display is turned on.
