Xperia 1
AndyTH
Xperia 1
Just bought. I opened three times with password. Then.. I can t open again. I think the only way would be to make a hard reset using butons but impossible to find the correct process. Companion and google method impossible.
2 ODPOW. 2
SleepIsForTheWe
Hold power button, then press and hold on power off and then tap ok, that should restart you in safe mode, then do a factory reset from settings.
Jonas
Guru
Hi @AndyTH, welcome to our forum!
We do not have any key combination to perform a reset of the device, only to force a restart/shutdown, but this does not impact the data on the device.
If you can't remember the screen lock on your device, you can reset your device using Xperia Companion by performing a software repair
Before you start with the repair, turn the device off and do not plug it in to your computer > Start Xperia Companion > tap "Software repair" and check the little box in the bottom left corner where it says "My device can't be powered on or is a Smartwatch 3" > proceed with the on-screen instructions.
I hope that helps!
