profile.country.NL.title
Strampke
Icon missing
Can someone tell me why there is no icon to access all the apps after disabling gesture navigation?
3 REPLIES 3
Jonas
Master
Hi @Strampke, thank you for the question! Slightly_smiling_Face
The Application screen is accessed by swiping the Home screen upwards. There is no setting which will make it possible to access all apps via an App tray icon instead.
I hope that answers your question! Slightly_smiling_Face
Strampke
Every new version gets more skinny.
Lost application screen, lost muting with volume down.
Creating a folder with shortcuts is the option left, isn't it?
Jonas
Master
@Strampke, this is the standard Android behaviour, same as the volume slider in Android Pie.
I do understand coming from using an application icon in all previous models to not having it can be quite the change though, but the swiping part is pretty neat and has already been available in earlier versions of Xperia Home.
