Hello everyone!
I recently tried to add the birthday as important date to my exisiting contacts on my Xperia 5 IV. Although the option is available when creating a new contact, it is not available when editing contacts. Is there a way to fix this inconsistency?
Best regards!
It seems more like a problem with the Google Contacts App, if it is the one you use.
Have you tried emptying the Cache Memory?
Also check that there is no Update.
Emptying the cache did resolve the issue, thank you!
