Hi,
i need to reset the password on my sony wi-fi since doing a firmware upgrade i cannot connect to my samsung s3 throught wi-fi, can it be done as the samsung keeps rejecting the original password?
also where can i get a spare battery tray for my NP-BG1 batteries?
thanking you in advance for any help
Hi Melovesushi,
welcome to the Sony User Community Forum..:smileyhappy:
Have you tried deleting/forgetting the wifi network up on your Samsung S3 & setting the wifi connection up again.?
As far as I am aware if you connect your Action Cam to your PC via USB you can check the wifi SSID & Password by doing the following..
Start click on Computer..
In Computer click on the Action Cam..
Followed by Info, then WIFI In..
As to the spare battery tray I can't seem to find any stockists you could try contacting Sony Support to see if they can supply one - Contact Sony
If sony support can't help let us know & we'll see if we can get some further information on possibly stockists..
Hi Melovesushi,
Thalamus thank you, yes i have tried that, doesnt seem to recognise the password given in the info text document so i was wondering if anyone knew a way of resetting it, will try contacting sony in the morning
type battery tray, just located one from a sony centre in tottenham court rd £39.99 for a piece of plastic.
i can buy 4 batteries for that !!!
Wi-fi sorted, password was case sensitive:smiley yahoo:,, thank you Thalmus, if anyone does not use their G tray please let me know
thank you
£39.99 does seem a expensive but it's often the case with some Sony parts, I remember the same thing with the stylus for the early readers..:smileyconfused:
You could always check Ebay or similar to see if there are any around, make sure you get the correct one though..:smileywink:
Ah yes WIFI passwords are always case sensative..:smileywink: Glad you've manage to connect succesfully now & good luck with finding your battery tray..:smileyhappy:
Hi ClaudiaGadelha,
Hi,
My AS15 micro usb port just broken out after 3 months of daily use (Sony refused to repair it within guarantee and repair cost would be much as a new cam). Is there any way to get my wifi password ? (WIFI_INF)?
Tnx
