A7rv Missing video files
antferg88
All my videos aren’t showing up on my card both in camera and when I plug into a computer
4 ODPOW. 4
profile.country.IT.title
Marino.Manolo
Genius
If they are not on the SD Card, is it possible that they were not recorded?
antferg88
They go on as I watch them back straight away. Then when I connect to the laptop they’re gone
danardeng
This the nightmare of all photographers/videographers.
Some checks:
 - after recorded and played in the camera, have you never extracted the SD?
 - have you inserted the SD in some other devises (for example another camera)?
 - have you explored all the folders?
 - if you check de property of the SD drive, how many space is occupied?
 - have you tried to use a recovery software?
HannahEd01
Hi antferg88, can you give some details? When did this start? How often does it happen? Does it happen with all your SD cards? What is the format your filming in?
Did you try taking the batteries out for two minutes? Removing and reinserting the card?
