APS-C Lens Question
SOLVED
nigelbond
Explorer
APS-C Lens Question
I'm new to the world of DSLR cameras so apologies if this is a dumb question.
I have a Sony Alpha 6000 with the kit lenses. The kit lenses are, I believe, APS-C lenses.
My question is do you have to apply the Crop Factor ratio to APS-C lenses or just to full frame lenses - ie is a 50mm APS-C lens really a 75mm lens or is it a genuine 50mm lens?
I've tried googling this but I can't find the answer.
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.BE.title
Portmixus
Hero
That is correct!
There is indeed no difference between a APS-C lens or a FF lens on a crop body, at least, concerning field of view.
In practice, things are a bit different. First of all, a FF lens has a larger image circle, therefore it will vignet less on an APS-C body.
FF lenses are generally sharper because you only use the center portion of a FF lens. But they are of course more expensive, larger and heavier compared to APS-C equivalents. It is also more difficult to implement optical image stabilisation (OSS) if the lens is already larger.
But 50mm is a special case: the 50mm F1.8 OSS is a beautiful exception: it's wonderfully sharp and even compared to the 1000 euro Zeiss 55mm F1.8. And although the Zeiss is better, the 50mm is barely worse IMHO. I have both and like both a lot!
Buying a FF lens for a crop body is therefore not such a smart idea, unless you are planning to upgrade some time in the future or if there are no alternatives available (some lenses will be less likely made voor APS-C, such as the 70-200 F OSS).
Sony Alpha Training
4 REPLIES 4
Portmixus
Hero
That's not a dumb question, it's a FAQ actually :wink:
A 50mm lens (even APS-C designed) is a 50mm lens on FF (full frame). So FF or APS-C lenses have the same focal lenght!
So the focal length stays the same, but of course, on a APS-C sensor (either APS-C designed or FF designed) the field of view is equivalent to 75mm on FF.
Hope that answers your question.
In short: 50mm APS-C = 50mm on FF
Sony Alpha Training
nigelbond
Explorer
Thanks. I think I understand what you're saying - ie in long form - that if you put a 50mm APS-C lens on a APS-C camera body or a 50mm full frame lens on an APS-C camera body, both will have the equivalent field of view as a 75mm full frame lens on a full frame body (given a crop factor of 1.5). Is that correct?
If that's the case, is there any other difference between an APS-C lens and a full frame lens on an APS-C camera body? Thanks again.
Portmixus
Hero
That is correct!
Sony Alpha Training
nigelbond
Explorer
That's brilliant, thanks. I'm not going to worry too much about other lenses at the moment - I've got to pay for the camera first :slight_smile: But it's useful information to know for future.
Nigel
