hi
i am considering upgrading the firmware on my slt-a55v to version 2.0.
i notice the upgrade program is the same for the a55 and the a55v.
does the program detect the model and install the correct firmware?
just asking as i do not want to brick my a55v.
and also, is the upgrade worthwhile for new features or bug fixes??
thanks for any reply.
Solved! Go to Solution.
Hi, welcome to the Sony Forums
The a55v tech support page has the official update and can be relied upon to get you to v2.0
Improvements, from the update page:
Cheers
Mick
Cheers
Mick
