Is there a vertical grip I can use on the Sony A290?
SOLVED
profile.country.en_GB.title
pocailse
Visitor
Cannot find a vertical grip for the Sony A290.
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi pocailse and welcome.
Unfortunately the A290 is not compatible with any Sony vertical grip.
Have a look here for the vertical grip compatibility of all Sony Alpha cameras: -
http://esupport.sony.com/US/perl/support-info.pl?template=&info_id=637
I am not sure if there are any third party offerings but I'm not sure I would trust an eBay grip!!
:thinking:
1 REPLY 1
Blencogo
:thinking:
