Nex-6 Hybrid Autofoucs Lens compatibility?
profile.country.en_GB.title
Nex_Newbie
Visitor
Hello y'all. I pocess a Nex 55-210mm lens but am thinking of upgrading the body to a Nex 6. However I read that the 6 comes with "Hybrid Autofocus" and a youtube clip suggested that lenses had to be compatible, which my 55-210 probably isnt. My question is really whether the 55-210 I have is redundant or if the Hybrid AF function is relevant to the smaller lenses only. Please help a newbie to the Nex arena!
5 REPLIES 5
Mick2011
New
Hi there, welcome to the Sony Forums :slight_smile:
The hybrid ('HDAF') system improves focus performance but shouldn't prevent you using most e-series lenses. If you have the SEL-55210 it should be fine. It's being sold as a bundled lens with some NEX-6 kits, so you shouldn't have a problem.
If you check this page and click the 'lenses' tab you can get a list of compatible glassware :cool:
Cheers
Mick
skybump
New
There's a firmware update for that lens here
http://www.sony.co.uk/support/en/product/NEX-6/updates
So you can use your current lens with both normal contrast focus and hybrid focus. It's only a little bit better, but it is better.
skybump
New
also the nex6 has a new firmware update that updates more lenses http://www.sony.co.uk/support/en/product/NEX-6/downloads/FW_NEX6_V101_WIN
profile.country.de_DE.title
cmosse
Contributor
Hello here are the direct links for the necessary updates which are now available. Please note that you have to update both camera AND lens firmware:
Update for the camera:
Update for the lens:
http://www.sony.co.uk/support/en/product/SEL55210/updates
blaireau_photo
Visitor
Hello all - and Nex_Newbie :slight_smile:
If you have performed the updates that have been indicated here, please let us know how you have got on.
Thanks,
Simon
