Technical drawing of VMC-BNCM1 timecode adaptor
videosoul
Member
Can anyone please point me in the direction (or share with me) a technical drawing of the VMC-BNCM1 timecode adaptor for the FX3/FX30? Looking to create an accessory in CAD, so would be helpful to have original/official measurements to work with. Thanks!
4 REPLIES 4
Anonymous
Not applicable
Hey @videosoul
I'd recommend contacting the professional department at Sony to be able to advise with that, as the cameras here as normal consumer cameras
videosoul
Member
Hmm. Well this is a forum for Alpha cameras, and this product is for ICLE cameras…
danardeng
Contributor
Unlike alpha cameras,  FX series gain a pro-support. It’s the reason (I think) of @Anonymous suggest.
anyway bncm1 has a really simple design, probably you take less time drawing by yourself than obtain official design
Anonymous
Not applicable
Yes, it's supported with the professional department, and on the support page of the camera, there is no section for accessory compatibility, only lenses https://www.sony.co.uk/electronics/support/camcorders-and-video-cameras-interchangeable-lens-camcord...
