2015 Bravia Android TV Issues
NickCo1979
Member
I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
6,373 REPLIES 6,373
frankie1g
Member
Funny how it taken a year 1to learnthos Sent from my Samsung device
manuelsal
Member
Fyi Channel list imported is messed up after restarting the TV, so don't bother trying to export it. Steps: - export current channel list to USB - edit file on PC using Sony tool - save edited file on USB - imported channel list on TV - TV restarted automatically - TV guide is update but after restarting again, the list changes, removed channels appears...
Unhappy owner of a KD-49X8307C
frogger38
Member
To be fair, Sony demonstrated the range at CES 2015 in February. With all the power of a multinational company, I just can't see how it can take 13 Months to develop software to provide PAP and HDD rec. It should have been sold finished. What is even worse Sony Customer Service rang me yesterday, and gave me an assurance that the missing features would definitely be available before 24th December 2015. OK they have had setbacks and want to get a stable platform before adding more, but the timescales are just wrong. The sets will be out of warranty before they are complete. Sent from my iPad
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
frogger38
Member
Odd how we can't log into the forum after the delay announcement. Sent from my iPad
Suzie14
Explorer
Hi Frogger, I see we are still locked out of the forum & support area. I believe this must be deliberate and when service is restored all the critical comments will have vanished. Will the fact that the support.sony.co.uk area is offline affect tomorrows update, certainly if anyone has trouble with the update they will not be able to access support.
frankie1g
Member
What the hell sony are you doing  Sent from my Samsung device
manuelsal
Member
Be patient guys, I just rebooted my TV and I finished testing the export/edit/import of digital and sat TV channels, it works until the TV with apparently no reasons starts changing it. Tomorrow I'll run new tests, it may be due to some of those incomprehensible setting such auto update services.
Suzie14
Explorer
Are Sony doing ANYTHING about the fact we cannot log into 'My Sony' or these forums? My TV is just updating, and we will struggle to give feedback... is this what is wanted?
adyjay33
Member
Probably yes...
KD-55X8509C LATEST FIRMWARE
NOT A HAPPY CUSTOMER!
Caledonian_TV
Contributor
How are these comments getting through? - I can't sign-in! "technical error" it says! ________________________ Matt Quinn, Managing Director, The Caledonian Television Company Ltd www.caledoniantv.com/ [email protected] DT1 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus
