Is there an app available in the store (model x90j), similar to Kodi (movie database, genres etc) which will also do the following......
1. tell me when a file was last played
2. prompt me which device to plug in when I click on the filename. Eg, I have files stored on several hdd's, so something like 'please insert WD Element SE', etc for a particular file.
thanks.
Hey joepineapples901, I'm not that expert but I've seen people using VLC.
Thanks Hannah, I'll certainly give it a look. I did find one call Nova Video Player, but it seems to recreate the film list, every time you run it (and takes a while to do so), so even if I only had one storage device, it still wouldn't be practical.
